Ir para o conteúdo principal
Asus Chromebook C523N Touchpad Replacement
Charlotte Arkwright
Charlotte Arkwright e 2 outros colaboradores
Última atualização em January 3, 2020
15 minutos
Fácil
Precisa de melhores imagens
If your Asus Chromebook C523N’s touchpad is not responding, use this guide to replace it.
Before beginning this guide, make sure the power is off and the laptop is disconnected from any power source.
O que você precisa
Ferramentas
Exibir mais…
  1. Asus Chromebook C523N Touchpad Replacement, Back Cover: passo 1, imagem 1 %32 Asus Chromebook C523N Touchpad Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Touchpad Replacement: passo 2, imagem 1 %32 Asus Chromebook C523N Touchpad Replacement: passo 2, imagem 2 %32
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Touchpad Replacement: passo 3, imagem 1 %32 Asus Chromebook C523N Touchpad Replacement: passo 3, imagem 2 %32
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Touchpad Replacement, Battery: passo 4, imagem 1 %32 Asus Chromebook C523N Touchpad Replacement, Battery: passo 4, imagem 2 %32 Asus Chromebook C523N Touchpad Replacement, Battery: passo 4, imagem 3 %32
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Gently disconnect the battery cable from the motherboard.
  5. Asus Chromebook C523N Touchpad Replacement: passo 5, imagem 1 %32 Asus Chromebook C523N Touchpad Replacement: passo 5, imagem 2 %32
    • Remove six 1.4 mm JIS #00 screws from the battery.
  6. Asus Chromebook C523N Touchpad Replacement: passo 6, imagem 1 %32
    • Remove the battery from the laptop.
  7. Asus Chromebook C523N Touchpad Replacement, Touchpad: passo 7, imagem 1 %32
    • Pull gently on the touchpad cable connector to disconnect.
  8. Asus Chromebook C523N Touchpad Replacement: passo 8, imagem 1 %32
    • Carefully, remove the tape from the touch pad only.
  9. Asus Chromebook C523N Touchpad Replacement: passo 9, imagem 1 %32
    • Remove the three 1.4 mm JIS #00 screws.
  10. Asus Chromebook C523N Touchpad Replacement: passo 10, imagem 1 %32 Asus Chromebook C523N Touchpad Replacement: passo 10, imagem 2 %32
    • Lift at the far edge of the touchpad to remove it.
Conclusão
3 comentários
Where do i buy the replacement touch pad
Anthony hughs - Responder
Very precise and clear. Thank you.
Raymond Trail - Responder
very clear instructions and photos. It was Easy, as described! One repairer had advised I buy a new Chromebook, bought an unused touchpad for £11. It took me a bit longer than the estimated 15 minutes, but this was the first time I’ve ever had the back off a laptop and attempted a repair/replacement, so took loads of photo’s on the way and took my time. I’ll definitely consider another DIY repair in the future.
John Outhwaite - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 941
