Ir para o conteúdo principal
Apple Wireless Keyboard Logic Board Replacement
Nicola
Nicola e 3 outros colaboradores
Última atualização em 20 de out de 2023
5 - 20 minutos
Moderado
Precisa de melhores imagens
Guia colaborativo
Introdução
Ir para o passo 1
You need a Metal spudger and a screwdriver
O que você precisa
Ferramentas
  1. Apple Wireless Keyboard Logic Board Replacement, Logic Board: passo 1, imagem 1 %32 Apple Wireless Keyboard Logic Board Replacement, Logic Board: passo 1, imagem 2 %32
    • Insert a metal spudger to open the plastic part under the Keyboard
  2. Apple Wireless Keyboard Logic Board Replacement: passo 2, imagem 1 %32
    • Remove the screw
  3. Apple Wireless Keyboard Logic Board Replacement: passo 3, imagem 1 %32 Apple Wireless Keyboard Logic Board Replacement: passo 3, imagem 2 %32 Apple Wireless Keyboard Logic Board Replacement: passo 3, imagem 3 %32
    • Pull the lock up and disconnect the connection cable
  4. Apple Wireless Keyboard Logic Board Replacement: passo 4, imagem 1 %32
    • Keeping the connection cable, push out the logic board's placement
    On some recent version of the keyboard, there's a plastic pin under the white logic board plastic holder, keeping the whole thing in position in the aluminium tube.
    You may have to pull slightly upward while pushing the logic board out of the tube to disengage the plastic pin.
    Kuf - Responder
  5. Apple Wireless Keyboard Logic Board Replacement: passo 5, imagem 1 %32
    • Unlock the latch of the logic board
  6. Apple Wireless Keyboard Logic Board Replacement: passo 6, imagem 1 %32
    • Remove the logic board from the placement
Conclusão
20 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Nicola
Membro desde: 11/14/13
638 Reputação
Autoria de 1 guia
9Comentários do guia
Hi, anyone know where its possible to buy this logic board? My bluetooth chip is apparently broken
steve - Responder
Which model of keyboard is this, because my A1255 doesn't disassemble like this - the battery terminal is solidly restrained inside the tube by means of a metal expansion ring. Doesn't seem user repairable :(
gordon jackson - Responder
My power button was stuck. The shell was dented. This was an easier way to access and remove the button so I was able to file the inside of the tube smooth so the button would move freely.
Tony - Responder
I have disassembled my keyboard as shown above, but now I need a replacement Wireless Keyboard Logic Board. I have not been able to find one. Any suggestions?
Martin Rubio - Responder
Very nice! in my case the flat cable was not properly connecting. I only found out when i opened the cap to the logic board and saw the cable sitting slanted in its connector. Put it back straight and now it works again. Cheers!!
mollymol - Responder
Great, now my Keyboard work thanks a lot!!!!!!!!
Maurizio - Responder
My keyboard empties a fully loaded set of batteries in 1 day, anybody had an idea wat it could be?
Wesley Looy - Responder
I bought used keyboard. It empties a set of batteries in less then a day. Plus it looses connections. Any ideas what this is?
koncan - Responder
Hello! My keyboard has some keys that stopped working: delete, return, r-shift, caps lock, r-option, tab. The rest of the keys work fine. Any suggestions?
Mariano Belgrano - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 28
Últimos 30 dias: 111
Ao todo: 49,673
