Ir para o conteúdo principal
Apple TV 2nd Generation Bottom Cover Replacement
O que você precisa
    • As the Apple TV doesn’t have any visible screws or points of entry, the first step is to use a couple of metal spudger to carefully loosen and remove the rubber base/bottom cover from the upper case.
  1. Apple TV 2nd Generation Bottom Cover Replacement: passo 2, imagem 1 %32
    • Position the replacement base over the exposed interior of the Apple TV. Gently press the cover down into the Apple TV until the interior tabs snap into place and the base is attached securely to the upper case.
Conclusão
Areej Bashawiri
Membro desde: 09/28/17
201 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 1,002
