Anne Pro 2 Case/Housing Replacement
Introdução
Ir para o passo 1This guide will show you how to replace the Anne Pro 2 keyboard housing to a Zero-Degree case. This case is better for smaller hands, as well as more ergonomic. You can 3D print this case (link provided in Parts section).
O que você precisa
Peças
Ferramentas
Exibir mais…
Unplug the Anne Pro 2 Keyboard.
Turn off the Anne Pro 2 Keyboard using the switch on the bottom.
Um comentário
Anne Pro 2 Software manage the illumination, open the mobile App and choose a pre-programmed scheme or design your own pattern, with a distinct colour for each key if desired. The programmes are easy to use and work on both Mac and PC.
Visit Here- https://www.techtoreview.com/top-picks/a...
