Ir para o conteúdo principal
Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement
Anna Gongre
Anna Gongre e 3 outros colaboradores
Última atualização em May 7, 2024
10 minutos
Fácil
Introdução
Ir para o passo 1
Caution: Handling of Sharp Objects
Please use caution when handling tweezers and keep out of reach of children.
If you notice that your phone has a delay in locking or turning the volume up and down, it is recommended that you change your Power/Volume button rocker.
O que você precisa
Ferramentas
  1. Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement, Power/Volume Button Rocker Replacement: passo 1, imagem 1 %32 Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement, Power/Volume Button Rocker Replacement: passo 1, imagem 2 %32
    • Begin by removing the back of the phone. Press your nail or a thin object in the bottom right-hand corner of the phone and gently press to release the back of the phone from the front.
  2. Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement: passo 2, imagem 1 %32 Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement: passo 2, imagem 2 %32
    • Once removed completely, use the back portion to disassemble the Power/Volume Button Rocker.
  3. Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove the middle insert of the elastic on the Power/Volume button rocker with tweezers.
  4. Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement: passo 4, imagem 1 %32 Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement: passo 4, imagem 2 %32 Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement: passo 4, imagem 3 %32
    • Remove the 3 elastic bands holding the rocker in place with tweezers.
  5. Alcatel Pop 4 Plus Power/Volume Button Rocker  Replacement: passo 5, imagem 1 %32
    • Once removed, place new rocker in same elastic slots. Follow instructions backwards to reassemble.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 343
