Ir para o conteúdo principal
Alcatel Pop 4 Plus Battery Replacement
Christopher Marcello
Christopher Marcello e 3 outros colaboradores
Última atualização em August 25, 2021
5 minutos
Fácil
Introdução
Ir para o passo 1
If your battery life doesn't last like it used to then this guide will show you how to take out your Alcatel Pop 4 Plus Battery for replacement with out damaging phone. It a simple process of removing the outside cover, secondary cover, and then swapping out the battery for a new one.
O que você precisa
Ferramentas
  • Spudger
    Spudger
  • Phillips #000 Screwdriver
  1. Alcatel Pop 4 Plus Battery Replacement, Battery: passo 1, imagem 1 %32 Alcatel Pop 4 Plus Battery Replacement, Battery: passo 1, imagem 2 %32
    • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
  2. Alcatel Pop 4 Plus Battery Replacement: passo 2, imagem 1 %32 Alcatel Pop 4 Plus Battery Replacement: passo 2, imagem 2 %32
    • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
  3. Alcatel Pop 4 Plus Battery Replacement: passo 3, imagem 1 %32
    • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
  4. Alcatel Pop 4 Plus Battery Replacement: passo 4, imagem 1 %32 Alcatel Pop 4 Plus Battery Replacement: passo 4, imagem 2 %32
    • Use the flat end of the spudger disconnect the battery from the motherboard.
    • Use the flat end of the spudger tool to pry out the battery.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team S20-G6, Passmore Spring 2018 Membro de USF Tampa, Team S20-G6, Passmore Spring 2018
USFT-PASSMORE-S18S20G6
4 Membros
Autoria de 12 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 28
Ao todo: 4,259
