Alcatel OneTouch Pop Icon Screen Replacement
Introdução
Ir para o passo 1Replacing the screen of the Alcatel OneTouch Pop Icon is a difficult task that should not be attempted without proper preparation. Make sure, that when using the metal spudger that may cause electrostatic discharge, to ground yourself by touching a metal object before using the spudger.
O que você precisa
Shut down the device
Flip the phone so that the screen is facing the surface you are working on
Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
Using the J000 Phillips screwdriver, remove the twelve silver 3mm screws.
Using the J000 Phillips screwdriver, remove the one green 3mm screw.
Ferramenta utilizada neste passo:Tweezers$4.99
Using tweezers, carefully detach the antenna from the motherboard.
Take a microwavable iOpener and heat it for 30 seconds.
Use the hot iOpener to heat up the screen.
Gently insert the plastic opening tool between the screen and the casing and use it to pry the screen loose from the casing.
Continue prying the screen from the casing until it can be fully removed.
But where do you find a replacement!!
But where do you get a replacement!! I can't find one, anywhere!!
10 outras pessoas executaram este guia.
2 comentários
No. Not if there fake wemon fixing things. I don't trust your company.
Cancel my order.
I don't have the tools to complete the job and repair my phone, so I'll have to get a new one but it was a very good tutorial. Lots of good pictures and very concise and clear. Thanks.
