Alcatel One Touch Evolve 2 LCD Screen Replacement
Introdução
Ir para o passo 1This guide will provide the necessary steps to replace the LCD screen from the Alcatel OneTouch Evolve 2.
O que você precisa
Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
Use a plastic opening tool to pop the speaker press-fit connector free.
Slide the edge of the tool under the connector and gently lift up on the edge; the connector should pop free with little force.
1Comentário do guia
Merci de nous donner l’équivalant de numériseur d'écran tactile pour Alcatel One Touch Evolve 2 4037T,l’origine est obsolète.
salut
