Ir para o conteúdo principal
Akai MPK25 Selector Knob Replacement
Anthony Zepeda
Anthony Zepeda e 5 outros colaboradores
Última atualização em January 28, 2014
30 - 45 minutos
Difícil
Guia do aluno destaque
Use this guide if any of the selector knobs get bent, broken, or stops working.
O que você precisa
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. Akai MPK25 Selector Knob Replacement, Face Plate: passo 1, imagem 1 %32
    • Remove all the selector knob covers by pulling them off.
  2. Akai MPK25 Selector Knob Replacement: passo 2, imagem 1 %32
    • Using needle nose pliers, remove the washers from the four corner selector knobs.
  3. Akai MPK25 Selector Knob Replacement: passo 3, imagem 1 %32
    • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
  4. Akai MPK25 Selector Knob Replacement: passo 4, imagem 1 %32 Akai MPK25 Selector Knob Replacement: passo 4, imagem 2 %32 Akai MPK25 Selector Knob Replacement: passo 4, imagem 3 %32
    • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
    • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
  5. Akai MPK25 Selector Knob Replacement: passo 5, imagem 1 %32 Akai MPK25 Selector Knob Replacement: passo 5, imagem 2 %32 Akai MPK25 Selector Knob Replacement: passo 5, imagem 3 %32
    • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
    • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
  6. Akai MPK25 Selector Knob Replacement, Selector Knob: passo 6, imagem 1 %32
    • Using a Phillips #2 screwdriver, remove the thirteen 9.8mm silver screws holding the mother board to the face plate.
  7. Akai MPK25 Selector Knob Replacement: passo 7, imagem 1 %32 Akai MPK25 Selector Knob Replacement: passo 7, imagem 2 %32
    • Using two plastic opening tools, slide the black locking mechanism on the ZIF connector towards you. This will remove the ribbon cable connecting the motherboard to the screen.
  8. Akai MPK25 Selector Knob Replacement: passo 8, imagem 1 %32 Akai MPK25 Selector Knob Replacement: passo 8, imagem 2 %32
    • Wiggle and pull out the ribbon cable connecting the mother board to the beat pads.
  9. Akai MPK25 Selector Knob Replacement: passo 9, imagem 1 %32 Akai MPK25 Selector Knob Replacement: passo 9, imagem 2 %32 Akai MPK25 Selector Knob Replacement: passo 9, imagem 3 %32
    • Remove the mother board completely from the face plate and identify the broken potentiometer.
  10. Akai MPK25 Selector Knob Replacement: passo 10, imagem 1 %32
    • Flip the mother board back over so the potentiometers are facing down and the leads are facing up. Then identify which leads correspond to the broken potentiometer.
    • Use a soldering iron with solder wick (or a solder sucker) in order to free the potentiometer from the mother board.
    • Add some leaded solder to the leads if your having trouble getting the factory solder to draw to the solder wick.
Conclusão
6 outras pessoas executaram este guia.
Anthony Zepeda
Membro desde: 01/30/13
303 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 20-6, Maness Winter 2013 Membro de Cal Poly, Team 20-6, Maness Winter 2013
CPSU-MANESS-W13S20G6
Membros da 5
Autoria de 6 guias
Um comentário
Thanks for putting together this great tutorial. Does anybody out there have the part number of the potentiometer?
discodamon - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 3,724
