Ir para o conteúdo principal
Adjusting Ibanez SR405QM Truss Rod
O que você precisa
  1. Adjusting Ibanez SR405QM Truss Rod, Strings: passo 1, imagem 1 %32
    • Loosen all of the strings completely by turning each tuning peg counter clockwise. Continue until there is no tension in the strings
  2. Adjusting Ibanez SR405QM Truss Rod: passo 2, imagem 1 %32
    • Remove each string by pulling it out of the string tree at the top and through the bridge at the bottom.
  3. Adjusting Ibanez SR405QM Truss Rod: passo 3, imagem 1 %32
    • Thread the largest new string through the bridge hole farthest from the knobs. Hold it firmly in place.
  4. Adjusting Ibanez SR405QM Truss Rod: passo 4, imagem 1 %32
    • Pull the string up to the corresponding string tree.
  5. Adjusting Ibanez SR405QM Truss Rod: passo 5, imagem 1 %32
    • Firmly grasp the middle of the string and pull it taut.
  6. Adjusting Ibanez SR405QM Truss Rod: passo 6, imagem 1 %32 Adjusting Ibanez SR405QM Truss Rod: passo 6, imagem 2 %32
    • On a taut string, measure one inch past the nut before using a pair of wire cutters to cut the string.
  7. Adjusting Ibanez SR405QM Truss Rod: passo 7, imagem 1 %32
    • Take the end of the string and insert it into the hole in the middle of the string tree.
  8. Adjusting Ibanez SR405QM Truss Rod: passo 8, imagem 1 %32
    • Bend the string sideways into the channel of the string tree.
  9. Adjusting Ibanez SR405QM Truss Rod: passo 9, imagem 1 %32
    • Use one hand to maintain tension in the string by grabbing the string and rotating the hand toward the fret board.
    • If tension is not retained it may result in uneven tension in the string tree, causing the tree to break.
  10. Adjusting Ibanez SR405QM Truss Rod: passo 10, imagem 1 %32
    • Rotate the tuning peg counterclockwise until the string is slightly taut, but not tight.
    • Check to ensure that the string is lined up with the proper notch in the nut.
    • You will have proper alignment when the sting bends at a minimum angle.
  11. Adjusting Ibanez SR405QM Truss Rod: passo 11, imagem 1 %32
    • Repeat steps 3-10 for each string.
    • Each string will progressively get closer to the knobs. It is not essential to progress from thick to thin strings, but it is important that they are connected to the proper string tree.
  12. Adjusting Ibanez SR405QM Truss Rod: passo 12, imagem 1 %32
    • Caution: Do not over tighten the strings. This can cause the strings to snap and could cause bodily injury. The strings are too tight when you have difficulty turning the tuning peg.
    • Tighten the string until it is close to the proper tuning. Use an electronic tuner or an online tuner that uses your computer's microphone. (Google: Online Tuner)
    • Note: Clockwise rotation of the tuning peg tightens the string and produces a higher pitch. Counter-clockwise rotation loosens the string causing a lower pitch.
    • Tune the thickest string to B, the second thickest string E, the next thickest to A, the next string to D, and the last string to G.
  13. Adjusting Ibanez SR405QM Truss Rod: passo 13, imagem 1 %32
    • Because the strings will change pitch as the guitar body deforms due to increased tension, repeat step 12 after each string is tuned individually.
    • Remove the strings from the bass according to the string installation guide.
  14. Adjusting Ibanez SR405QM Truss Rod: passo 15, imagem 1 %32
    • Locate the screws covering the truss rod.
  15. Adjusting Ibanez SR405QM Truss Rod: passo 16, imagem 1 %32 Adjusting Ibanez SR405QM Truss Rod: passo 16, imagem 2 %32
    • Remove each of the screws with the Philips #1 screwdriver.
    • Remove the plate covering the truss rod by sliding it off.
  16. Adjusting Ibanez SR405QM Truss Rod: passo 17, imagem 1 %32 Adjusting Ibanez SR405QM Truss Rod: passo 17, imagem 2 %32
    • Locate the truss rod hex nut.
    • If your fret board is bowing upward towards the strings, loosen the truss rod by turn by turning the hex wrench a quarter to half turn counter-clockwise.
    • If your fret board is bowing down away from the strings, tighten the truss rod by turning the hex wrench a quarter to half a turn clockwise.
Conclusão
You've successfully adjusted the truss rod!
Chris Pittner
Membro desde: 01/11/13
220 Reputação
7 Guias de autoria
Equipe
Cal Poly, Team 5-18, Forte Winter 2013 Membro de Cal Poly, Team 5-18, Forte Winter 2013
CPSU-FORTE-W13S5G18
4 Membros
9 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 42
Últimos 30 dias: 290
Duração total: 13,563
