Ir para o conteúdo principal
Adding a Power Fuse to U2C on Troodon with Can Bus
AJ Pereira
AJ Pereira e 2 outros colaboradores
Última atualização em August 1, 2024
Nenhuma estimativa
Moderado
Guia colaborativo
  1. Adding a Power Fuse to U2C on Troodon with Can Bus, Prepair For install: passo 1, imagem 1 %32 Adding a Power Fuse to U2C on Troodon with Can Bus, Prepair For install: passo 1, imagem 2 %32 Adding a Power Fuse to U2C on Troodon with Can Bus, Prepair For install: passo 1, imagem 3 %32
    • Shut down printer and unplug the power cable from the printer
    • Loosen the front panel screws, then remove the front cover panel and set the cover down in front of the machine.
    • Note, you will need about 6-8 inches of space in front of the machine to set the front cover panel down on, so you can work on the machine
    • Locate the power cable coming from the power supply.
    • Pull it forward slowly
    • Give your self about 6-8 inches of cable from the U2C power terminal and cut the power cable
  2. Adding a Power Fuse to U2C on Troodon with Can Bus, Prepair the wire: passo 2, imagem 1 %32 Adding a Power Fuse to U2C on Troodon with Can Bus, Prepair the wire: passo 2, imagem 2 %32 Adding a Power Fuse to U2C on Troodon with Can Bus, Prepair the wire: passo 2, imagem 3 %32
    • Once the cable is cut, strip both ends of the wire back 8-10 mm.
  3. Adding a Power Fuse to U2C on Troodon with Can Bus: passo 3, imagem 1 %32 Adding a Power Fuse to U2C on Troodon with Can Bus: passo 3, imagem 2 %32 Adding a Power Fuse to U2C on Troodon with Can Bus: passo 3, imagem 3 %32
    • The wire is going connect to go into the Wago connector then through the fuse and back to the U2C
    • The fuse holder/ Wago is non - directional, so it does not matter which side is in out. Either way will pass the power wire through the fuse correctly.
    • Lift up the orange lever on an open terminal and insert one stripped end as far into the hole as possible then snap the lever closed. Repeat for the other side.
Conclusão
AJ Pereira
Membro desde: 05/29/20
2.707 Reputação
Autoria de 16 guias
Equipe
Tiny Machines 3D Membro de Tiny Machines 3D
Community
5 Membros
Autoria de 41 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Ao todo: 107
