Ir para o conteúdo principal
Acer Swift X N20C12 Trackpad Replacement
Abrar
Abrar e 4 outros colaboradores
Última atualização em December 28, 2023
20 minutos
Moderado
Precisa de mais images
Introdução
Ir para o passo 1
If you have been experiencing issues with your laptop's trackpad? Perhaps it's not responding as smoothly as it used to, or maybe it's entirely unresponsive. In such situations, replacing the trackpad can be a practical solution to restore your laptop's functionality and user experience. In this guide, we'll explore the steps to replace the trackpad.
O que você precisa
Ferramentas
Exibir mais…
  1. Acer Swift X N20C12 Trackpad Replacement, Lower Case: passo 1, imagem 1 %32
    • Use a Torx T5 screwdriver to remove the eleven screws that secure the lower case.
  2. Acer Swift X N20C12 Trackpad Replacement: passo 2, imagem 1 %32
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the pick around the perimeter while prying until the lower case releases.
    • Remove the lower case.
  3. Acer Swift X N20C12 Trackpad Replacement, Battery: passo 3, imagem 1 %32
    • Grasp the battery connector and pull it directly out of its socket.
    • Use a Phillips #1 screwdriver to remove the two 4.8 mm screws that secure the battery.
  4. Acer Swift X N20C12 Trackpad Replacement: passo 4, imagem 1 %32
    • Lift the battery up and out of the chassis.
  5. Acer Swift X N20C12 Trackpad Replacement, Trackpad: passo 5, imagem 1 %32
    • Use a Phillips # 1 screwdriver to remove the 2.9 mm screws that secure the trackpad.
    • Disconnect the trackpad connector.
  6. Acer Swift X N20C12 Trackpad Replacement: passo 6, imagem 1 %32
    • Lift the trackpad up and out of the chassis.
Conclusão
Abrar
Membro desde: 09/08/23
472 Reputação
Autoria de 5 guias
Equipe
Gateway, Team 1-2, Pee Fall 2023 Membro de Gateway, Team 1-2, Pee Fall 2023
GCC-PEE-F23S1G2
5 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 17
Ao todo: 228
