Ir para o conteúdo principal
Acer Swift X N20C12 Display Assembly Replacement
Abrar
Abrar e 4 outros colaboradores
Última atualização em December 28, 2023
25 - 35 minutos
Moderado
Precisa de mais images
Precisa de melhores imagens
Introdução
Ir para o passo 1
If you have display assembly , Whether you've encountered a cracked screen, malfunctioning display, or other issues with your laptop or monitor, this step-by-step walkthrough will help you replace the display assembly and get your device back to optimal working condition. With detailed instructions and tips, we'll guide you through the process, ensuring a smooth and successful replacement of your display assembly.
O que você precisa
Ferramentas
Exibir mais…
  1. Acer Swift X N20C12 Display Assembly Replacement, Lower Case: passo 1, imagem 1 %32
    • Use a Torx T5 screwdriver to remove the eleven screws that secure the lower case.
  2. Acer Swift X N20C12 Display Assembly Replacement: passo 2, imagem 1 %32
    • Insert an opening pick in the seam between the lower case and chassis.
    • Slide the pick around the perimeter while prying until the lower case releases.
    • Remove the lower case.
  3. Acer Swift X N20C12 Display Assembly Replacement, Display Assembly: passo 3, imagem 1 %32 Acer Swift X N20C12 Display Assembly Replacement, Display Assembly: passo 3, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the 5.5 mm screws securing the hinges.
    • Disconnect the display cable.
  4. Acer Swift X N20C12 Display Assembly Replacement: passo 4, imagem 1 %32
    • Lift and remove the display assembly.
Conclusão
Abrar
Membro desde: 09/08/23
472 Reputação
Autoria de 5 guias
Equipe
Gateway, Team 1-2, Pee Fall 2023 Membro de Gateway, Team 1-2, Pee Fall 2023
GCC-PEE-F23S1G2
5 Membros
Autoria de 5 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 28
Ao todo: 361
