Ir para o conteúdo principal
Acer Chromebook C710-2847 Back Cover Replacement
Bradley Pavy
Bradley Pavy e 5 outros colaboradores
Última atualização em March 2, 2021
2 minutos
Fácil
Removing the back cover exposes all the internal components of the laptop. Removing the back cover will void your warranty, so use caution not to damage any of the components inside.
O que você precisa
Ferramentas
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Acer Chromebook C710-2847 Back Cover Replacement, Battery: passo 1, imagem 1 %32 Acer Chromebook C710-2847 Back Cover Replacement, Battery: passo 1, imagem 2 %32
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Back Cover Replacement: passo 2, imagem 1 %32 Acer Chromebook C710-2847 Back Cover Replacement: passo 2, imagem 2 %32
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 Back Cover Replacement, Acer Chromebook C710-2847 Back Cover Replacement: passo 3, imagem 1 %32
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
  4. Acer Chromebook C710-2847 Back Cover Replacement: passo 4, imagem 1 %32 Acer Chromebook C710-2847 Back Cover Replacement: passo 4, imagem 2 %32
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
Conclusão
9 outras pessoas executaram este guia.
Bradley Pavy
Membro desde: 09/30/13
1.257 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 13-3, Forte Fall 2013 Membro de Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
Membros da 5
Autoria de 14 guias
Um comentário
Once you have the back cover off, you can insert aluminum foil into a tiny connector, which will allow you to flash the BIOS and boot any operating system, not just ChromeOS. Using this method, I completely wiped ChromeOS from my C710 and installed Ubuntu 16.04 LTS. Definitely worth it, because now I have a sub-$300 Linux netbook with a removable battery, standard keyboard with CAPS lock (most Chromebooks don't), and no ugly Windows key.
Uncle Happy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 10
Duração total: 6,390
