Acer Aspire TimelineX 4830T-6682 RAM Replacement
Introdução
Ir para o passo 1This guide will help with opening up the small panel on the back of the computer to expose the RAM. This will allow the reader to replace or increase RAM on their computer.
O que você precisa
Remove the single screw with a Phillips #0 screwdriver.
Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
After the panel has been removed, locate the RAM. It should be on the lower right.
There are pins around the RAM that need to be pulled back. After the pins are removed, pull the RAM chip towards you to remove it.
Uma outra pessoa concluiu este guia.
