Ir para o conteúdo principal
Acer Aspire TimelineX 4830T-6682 CPU Replacement
Jon Brunsell
Jon Brunsell e 2 outros colaboradores
Última atualização em August 12, 2019
8 minutos
Moderado
Introdução
Ir para o passo 1
The CPU is not a common failure component, but may fail due to a failed cooling fan that caused it to overheat.
This guide provides simple steps to replace the CPU on the Acer Aspire TimelineX 4830T-6682 using minimal tools that can be acquired locally, or through iFixit. Please make sure and follow the prerequisite procedures.
O que você precisa
Ferramentas
Exibir mais…
  1. Acer Aspire TimelineX 4830T-6682 CPU Replacement, Lower Back Panel: passo 1, imagem 1 %32 Acer Aspire TimelineX 4830T-6682 CPU Replacement, Lower Back Panel: passo 1, imagem 2 %32 Acer Aspire TimelineX 4830T-6682 CPU Replacement, Lower Back Panel: passo 1, imagem 3 %32
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
  2. Acer Aspire TimelineX 4830T-6682 CPU Replacement, RAM: passo 2, imagem 1 %32 Acer Aspire TimelineX 4830T-6682 CPU Replacement, RAM: passo 2, imagem 2 %32 Acer Aspire TimelineX 4830T-6682 CPU Replacement, RAM: passo 2, imagem 3 %32
    • After the panel has been removed, locate the RAM. It should be on the lower right.
    • There are pins around the RAM that need to be pulled back. After the pins are removed, pull the RAM chip towards you to remove it.
  3. Acer Aspire TimelineX 4830T-6682 CPU Replacement, Keyboard: passo 3, imagem 1 %32
    • Remove the eleven screws that hold that back panel to the laptop using a J0 Phillips screwdriver bit.
  4. Acer Aspire TimelineX 4830T-6682 CPU Replacement: passo 4, imagem 1 %32 Acer Aspire TimelineX 4830T-6682 CPU Replacement: passo 4, imagem 2 %32 Acer Aspire TimelineX 4830T-6682 CPU Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    $3.99
    • Place the laptop in the upright position, the lower front touchpad panel should be easily detatched at this point.
    • Remove the lower front touchpad panel by using an angled tweezers to disconnect the only wired tape connected to the motherboard.
  5. Acer Aspire TimelineX 4830T-6682 CPU Replacement: passo 5, imagem 1 %32
    • Next, disconnect the 4 wired tapes of the keyboard from the motherboard just like we did with the lower front touchpad panel.
  6. Acer Aspire TimelineX 4830T-6682 CPU Replacement: passo 6, imagem 1 %32 Acer Aspire TimelineX 4830T-6682 CPU Replacement: passo 6, imagem 2 %32
    • Finally, using an opening tool, gently pry along the edge of the keyboard to separate it from the laptop.
  7. Acer Aspire TimelineX 4830T-6682 CPU Replacement, Battery: passo 7, imagem 1 %32
    • The battery will be on the side closest to the screen.
    • Gently lift it out. It will still be attached by white, red, and black wires.
  8. Acer Aspire TimelineX 4830T-6682 CPU Replacement: passo 8, imagem 1 %32 Acer Aspire TimelineX 4830T-6682 CPU Replacement: passo 8, imagem 2 %32
    • Pull the white plug, it should easily detach.
    • Remove the battery from the device.
  9. Acer Aspire TimelineX 4830T-6682 CPU Replacement, CPU: passo 9, imagem 1 %32
    • Turn the CPU screw counterclockwise 180 degrees with a Flathead 2.5mm screwdriver
  10. Acer Aspire TimelineX 4830T-6682 CPU Replacement: passo 10, imagem 1 %32
    • Remove the CPU vertically from the socket being careful not to bend the CPU pins
Conclusão
Uma outra pessoa concluiu este guia.
Jon Brunsell
Membro desde: 07/10/19
592 Reputação
Autoria de 6 guias
Equipe
IUPUI, Team S1-G1, Beck Spring 2020 Membro de IUPUI, Team S1-G1, Beck Spring 2020
IUPUI-BECK-S20S1G1
3 Membros
Autoria de 6 guias
3 comentários
Followed instructions computer now dosnt turn on
Ian Burgess - Responder
Hello Ian,
If you would like me to help troubleshoot your computer, please provide more details by answering the following questions?
Jon Brunsell - Responder
Was the computer booting before following the CPU replacement instructions?
What troubleshooting was completed to determine the CPU had to be replaced?
Was the CPU replacement part verified as working before installation?
Is the computer powering up to any screen, showing partial boot?
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 867
