Acer Aspire TimelineU M5-481TG Battery Replacement
Introdução
Ir para o passo 1The Acer TimelineU M5-481TG laptop is a 14-inch Ultrabook that is the smaller version to the Aspire TimelineU M5-581TG-6666 weighing in at 4.4 lbs. Several battery models exist for this laptop such as the AP12A3i, AP12A4i, 3ICP7/67/90, KT. 00303.002, BT. 00304.011. Other generic batteries exist but ensure that they are compatible with the M5-481TG model laptop.
Before performing any repairs, make sure the Acer Aspire TimelineU M5-481TG laptop is fully powered off and disconnected from its charger. Removing the battery includes first removing the keyboard and gently disconnecting wires to lift up the motherboard. Here is an article on how to identify a bad battery.
O que você precisa
With the laptop closed and powered off, place the laptop screen side down.
Turn the laptop so that the hinges are closest to you.
Remove sixteen 6 mm screws from the bottom of the laptop with the Phillips #00 screwdriver.
Hold the keyboard open with one hand to extend the three cables (white, black and copper) still connecting the bottom of the keyboard to the back case.
Use your fingernail to flip up the small retaining flap of each zero insertion force connector and then gently pull each ribbon cable out one at a time.
Gently disconnect the silver cable that stretches over the battery by using your fingernail to flip up the small retaining flaps on both sides of the zero insertion force connector.
Gently lift up the black-covered cables that remain connected to the motherboard at the bottom left of the laptop base.
Move the cables toward the bottom edge of the laptop closest to you without disconnecting them.
Carefully lift up the motherboard and slide the battery to the left to pull it out.
Step 9 the red arrow pointing to that cord, I'm having problems and I think that's the issue I'm having. I bumped it loose and now I cant turn on the laptop with out plugging it in. Please help me figure out what that cord does.
