Ir para o conteúdo principal
Acer Aspire R7 AC Socket Replacement
Andrew Rodiek
Andrew Rodiek e 2 outros colaboradores
Última atualização em June 12, 2015
10 minutos
Fácil
Estudante em progresso
O que você precisa
Ferramentas
Exibir mais…
  1. Acer Aspire R7 AC Socket Replacement, Cover: passo 1, imagem 1 %32
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 AC Socket Replacement: passo 2, imagem 1 %32 Acer Aspire R7 AC Socket Replacement: passo 2, imagem 2 %32 Acer Aspire R7 AC Socket Replacement: passo 2, imagem 3 %32
    • Remove six 6mm T7 screws.
    • Remove four 4mm T7 screws.
    • Remove two 10mm T7 screws
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining two10mm T7 screws.
  3. Acer Aspire R7 AC Socket Replacement: passo 3, imagem 1 %32
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 AC Socket Replacement, AC Socket: passo 4, imagem 1 %32 Acer Aspire R7 AC Socket Replacement, AC Socket: passo 4, imagem 2 %32 Acer Aspire R7 AC Socket Replacement, AC Socket: passo 4, imagem 3 %32
    • Locate the AC Socket ribbon connector
    • Loosen the ribbon connector using the plastic opening tool
    • Pull the ribbon connector away from the motherboard
  5. Acer Aspire R7 AC Socket Replacement: passo 5, imagem 1 %32 Acer Aspire R7 AC Socket Replacement: passo 5, imagem 2 %32
    • Use the plastic opening tool to pry up on the yellow tabs holding the Socket in place
    • There is two sided tape holding this component to the case
    • Once the tape on the Socket is loose, pull up and away from the case to remove it.
Conclusão
Uma outra pessoa concluiu este guia.
Andrew Rodiek
Membro desde: 01/13/15
601 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 3-4, Hickman Winter 2015 Membro de USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 16
Duração total: 1,467
