Acer Aspire R R5-471T-51UN SSD Replacement
Introdução
Vá para o passo 1If you ever need to replace the SSD in your Acer Aspire R R5-471T-51UN, then this guide is for you. Here, you will be using tools like the Jimmy and the Phillips #0 screwdriver to disconnect certain components. Step 5 asks you to be cautious when removing the battery. Before you begin, power off the device and disconnect from any external connections.
O que você precisa
Ferramentas
Flip your laptop over so the bottom is facing you.
Remove the twelve 5 mm screws with a Phillips #0 screwdriver.
Using the Phillips #0 screwdriver, unscrew the single 5mm screw holding the SSD in place.
