Ir para o conteúdo principal
Acer Aspire ES1-711-P1UV Hard Drive Replacement
O que você precisa
  1. Acer Aspire ES1-711-P1UV Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Hard Drive Replacement: passo 2, imagem 1 %32
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Hard Drive Replacement: passo 3, imagem 1 %32
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Hard Drive Replacement: passo 4, imagem 1 %32
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
  5. Acer Aspire ES1-711-P1UV Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32
    • Remove the four 4.5 mm screws that hold the hard drive in place.
  6. Acer Aspire ES1-711-P1UV Hard Drive Replacement: passo 6, imagem 1 %32 Acer Aspire ES1-711-P1UV Hard Drive Replacement: passo 6, imagem 2 %32
    • Remove the tabs holding the hard drive in place.
    • Remove the hard drive.
Conclusão
3 outras pessoas executaram este guia.
0 Guide Comments
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 17
Ao todo: 2,651
