Ir para o conteúdo principal
Acer Aspire E5-721-64T8 battery  Replacement
Reem
Reem e 3 outros colaboradores
Última atualização em June 25, 2018
5 - 10 minutos
Fácil
If the laptop is failing to turn on or hold a charge, it may be because of a faulty battery. This guide will teach you how to remove and therefor replace the battery of this laptop. Be sure to disconnect the AC adapter to your laptop if it's connected before removal.
O que você precisa
Ferramentas
  1. Acer Aspire E5-721-64T8 battery  Replacement, Battery: passo 1, imagem 1 %32
    • Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
  2. Acer Aspire E5-721-64T8 battery  Replacement: passo 2, imagem 1 %32
    • Using the plastic opening tool, lift up on the side opposite of the Ethernet connector.
    • With the plastic opening tool under the bottom panel, work your way around the perimeter until the panel separates.
  3. Acer Aspire E5-721-64T8 battery  Replacement: passo 3, imagem 1 %32
    • Remove the two 6mm Phillips #0 screws from the battery.
  4. Acer Aspire E5-721-64T8 battery  Replacement: passo 4, imagem 1 %32 Acer Aspire E5-721-64T8 battery  Replacement: passo 4, imagem 2 %32
    • Disconnect the battery from the motherboard.
    • Pull the battery up and out of the laptop.
Conclusão
Reem
Membro desde: 01/25/18
109 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S7-G3, Passmore Spring 2018 Membro de USF Tampa, Team S7-G3, Passmore Spring 2018
USFT-PASSMORE-S18S7G3
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 648
