Ir para o conteúdo principal
Acer Aspire E5-571P-55TL Battery Replacement
Max Piekos
Max Piekos e 3 outros colaboradores
Última atualização em May 12, 2022
1 - 2 minutos
Muito fácil
Introdução
Ir para o passo 1
If your Acer Aspire E5-571P-55TL is not holding a charge, or won't turn on at all, the battery may be damaged or run out of power. The battery is a component that supplies power to the device, allowing it to work without a power cord. Over many charges, the temporary lifespan of the battery decreases. To see common issues which may require battery replacement, see our Acer E5-571P-55TL troubleshooting guide.
This guide will explain how to replace the battery for the Acer E5-571P-55TL. Before performing actions in this guide be sure to power off your laptop and remove the power adapter.
If the battery you are replacing looks damaged or swollen be careful handling it. Damaged batteries may be potentially hazardous. Use caution when handling the damaged battery.
O que você precisa
Ferramentas
  • Spudger
    Spudger
  1. Acer Aspire E5-571P-55TL Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure that laptop is turned off.
    • Turn the laptop upside down with the battery facing you.
  2. Acer Aspire E5-571P-55TL Battery Replacement: passo 2, imagem 1 %32
    • Place the Spudger into the battery lock and slide it to the left until you hear the battery unlock.
  3. Acer Aspire E5-571P-55TL Battery Replacement: passo 3, imagem 1 %32 Acer Aspire E5-571P-55TL Battery Replacement: passo 3, imagem 2 %32
    • Pull the battery towards you to remove it from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Max Piekos
Membro desde: 03/23/22
459 Reputação
Autoria de 4 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 297
