Acer Aspire 7736Z-4809 LCD Module Replacement
Introdução
Ir para o passo 1Before replacing the LCD module, make sure to back up your laptop.
O que você precisa
Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
Ferramenta utilizada neste passo:Tweezers$4.99
Remove the white antenna of the wireless module.
Use the Phillips #1 screwdriver to remove the two 6.5mm Phillips #1 screws.
Use the Phillips #1 screwdriver to remove the three 4.5mm Phillips #1 screws.
Use tweezers to pull the black and white antennas out of the hole.
Uma outra pessoa concluiu este guia.
