Ir para o conteúdo principal
Acer Aspire 5100 LCD Monitor Replacement
Brad Rollinson
Brad Rollinson e 8 outros colaboradores
Última atualização em May 11, 2021
20 - 30 minutos
Difícil
Introdução
Ir para o passo 1
If your Acer Aspire screen (model 5100) isn’t producing a clear picture and instead outputs distorted images or intermittent/dead pixels, use this guide to replace the monitor.
The monitor transmits visual data to users through thousands of small pixels. A faulty monitor will transmit distorted or unclear images or no images at all.
Before using this guide, inspect the monitor for any debris that may be interfering with screen quality. Typically, any minute pieces of dust can be removed using an ESD-safe brush or small, damp towel. Be sure to completely shut down your laptop on and off at least two times to confirm that the faulty hardware is the monitor itself.
Before beginning, be sure to turn off your laptop completely and disconnect it from any external power source(s) or monitors if possible.
O que você precisa
Peças
Ferramentas
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Exibir mais…
  1. Acer Aspire 5100 LCD Monitor Replacement, Keyboard: passo 1, imagem 1 %32 Acer Aspire 5100 LCD Monitor Replacement, Keyboard: passo 1, imagem 2 %32
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 LCD Monitor Replacement: passo 2, imagem 1 %32 Acer Aspire 5100 LCD Monitor Replacement: passo 2, imagem 2 %32 Acer Aspire 5100 LCD Monitor Replacement: passo 2, imagem 3 %32
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 LCD Monitor Replacement: passo 3, imagem 1 %32
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
  4. Acer Aspire 5100 LCD Monitor Replacement, LCD Monitor: passo 4, imagem 1 %32
    • Remove the two screws from each corner beneath the LCD screen.
  5. Acer Aspire 5100 LCD Monitor Replacement: passo 5, imagem 1 %32 Acer Aspire 5100 LCD Monitor Replacement: passo 5, imagem 2 %32
    • Detach the white rectangle located on the motherboard at the end of the wire connected to the LCD screen.
  6. Acer Aspire 5100 LCD Monitor Replacement: passo 6, imagem 1 %32 Acer Aspire 5100 LCD Monitor Replacement: passo 6, imagem 2 %32
    • Flip the laptop upside down.
    • Remove the four screws from the back panel of the laptop.
    • Lift the panel up and set it aside.
  7. Acer Aspire 5100 LCD Monitor Replacement: passo 7, imagem 1 %32
    • Detach the black and white wire.
    • You do not need to remove the cooling fan.
  8. Acer Aspire 5100 LCD Monitor Replacement: passo 8, imagem 1 %32
    • Lift up the monitor to detach it.
Conclusão
8 outras pessoas executaram este guia.
Brad Rollinson
Membro desde: 09/29/10
1.113 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 14-39, Forte Fall 2010 Membro de Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Membros
Autoria de 10 guias
1Comentário do guia
There are 2 screws at the back corners on the bottom cover that are holding the screen down. They need to be removed in order for the screen to be lifted.
Kar Wong - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 15,570
