Ir para o conteúdo principal
Acer Aspire 3 A315-58-350L Battery Replacement
Evan Sandoval
Evan Sandoval e 3 outros colaboradores
Última atualização em February 14, 2025
10 - 20 minutos
Fácil
Guia do aluno destaque
Introdução
Ir para o passo 1
The battery is the power source of the laptop, allowing it to be a device you can carry anywhere. If you feel like your battery is not holding a charge like it used to or is dying when it shows it has more battery life, then it is time for a new battery. This is an easy fix that only requires unscrewing a few screws. Make sure that the device is off for at least 1 minute and unplugged from anything.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Acer Aspire 3 A315-58-350L Battery Replacement, Lower Case: passo 1, imagem 1 %32 Acer Aspire 3 A315-58-350L Battery Replacement, Lower Case: passo 1, imagem 2 %32
    • Remove the eleven 7 mm Phillips screws that secure the lower case.
  2. Acer Aspire 3 A315-58-350L Battery Replacement: passo 2, imagem 1 %32 Acer Aspire 3 A315-58-350L Battery Replacement: passo 2, imagem 2 %32 Acer Aspire 3 A315-58-350L Battery Replacement: passo 2, imagem 3 %32
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry along the perimeter until the lower case releases.
    • Lift off the lower case.
  3. Acer Aspire 3 A315-58-350L Battery Replacement, Battery: passo 3, imagem 1 %32 Acer Aspire 3 A315-58-350L Battery Replacement, Battery: passo 3, imagem 2 %32
    • Remove the two 4 mm Phillips screws that secure the battery.
  4. Acer Aspire 3 A315-58-350L Battery Replacement: passo 4, imagem 1 %32 Acer Aspire 3 A315-58-350L Battery Replacement: passo 4, imagem 2 %32 Acer Aspire 3 A315-58-350L Battery Replacement: passo 4, imagem 3 %32
    • Use tweezers to peel off the black strips of tape on the top of the battery
  5. Acer Aspire 3 A315-58-350L Battery Replacement: passo 5, imagem 1 %32 Acer Aspire 3 A315-58-350L Battery Replacement: passo 5, imagem 2 %32
    • Use tweezers to grip the white battery connector and pull it directly out of its motherboard port.
    • Do not pull on the wires.
  6. Acer Aspire 3 A315-58-350L Battery Replacement: passo 6, imagem 1 %32 Acer Aspire 3 A315-58-350L Battery Replacement: passo 6, imagem 2 %32 Acer Aspire 3 A315-58-350L Battery Replacement: passo 6, imagem 3 %32
    • Lift the battery up and out of the chassis.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 87
Ao todo: 472
