Ir para o conteúdo principal
APS Tech 101629 SCSI Connections Replacement
Patrick Meyer
Patrick Meyer e 4 outros colaboradores
Última atualização em May 28, 2023
20 - 30 minutos
Moderada
Guia em destaque
The guide will teach you how to replace any faulty SCSI Connections at the back of the device. It requires the case to be opened, so any warranties covering the device will be voided.
O que você precisa
Ferramentas
  1. APS Tech 101629 SCSI Connections Replacement, External Casing: passo 1, imagem 1 %32 APS Tech 101629 SCSI Connections Replacement, External Casing: passo 1, imagem 2 %32 APS Tech 101629 SCSI Connections Replacement, External Casing: passo 1, imagem 3 %32
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 SCSI Connections Replacement: passo 2, imagem 1 %32 APS Tech 101629 SCSI Connections Replacement: passo 2, imagem 2 %32
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 SCSI Connections Replacement: passo 3, imagem 1 %32 APS Tech 101629 SCSI Connections Replacement: passo 3, imagem 2 %32
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 SCSI Connections Replacement: passo 4, imagem 1 %32
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 SCSI Connections Replacement: passo 5, imagem 1 %32 APS Tech 101629 SCSI Connections Replacement: passo 5, imagem 2 %32
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 SCSI Connections Replacement, Internal Drive Component: passo 6, imagem 1 %32 APS Tech 101629 SCSI Connections Replacement, Internal Drive Component: passo 6, imagem 2 %32
    • Flip so device is upside down.
    • Remove 4 screws with Phillips #1 screw driver.
    • Be sure to save the washers that seperate the screws from the baseplate for reassembly.
  7. APS Tech 101629 SCSI Connections Replacement: passo 7, imagem 1 %32 APS Tech 101629 SCSI Connections Replacement: passo 7, imagem 2 %32
    • Slide the internal drive component away from the back of the device.
    • Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
    • Audio Connection
    • SCSI ID
    • Terminate On
    • SCSI Connection
    • DC Input (power)
  8. APS Tech 101629 SCSI Connections Replacement, SCSI Connections: passo 8, imagem 1 %32 APS Tech 101629 SCSI Connections Replacement, SCSI Connections: passo 8, imagem 2 %32 APS Tech 101629 SCSI Connections Replacement, SCSI Connections: passo 8, imagem 3 %32
    • Remove the four Phillips #1 Screws from back panel.
    • Once the screws are removed, the two connections are easily removed from the body.
Conclusão
Patrick Meyer
Membro desde: 04/10/11
83 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 24-60, Amido Spring 2011 Membro de Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 906
