Ir para o conteúdo principal
APS Tech 101629 Internal Drive Component Replacement
Alexis Weckel
Alexis Weckel e 4 outros colaboradores
Última atualização em May 28, 2023
10 - 20 minutos
Fácil
This repair guide will walk you through the steps to removing and replacing the internal drive component of your APS Tech 101629 CD-Drive. First the external casing will need to be removed.
O que você precisa
Ferramentas
  1. APS Tech 101629 Internal Drive Component Replacement, External Casing: passo 1, imagem 1 %32 APS Tech 101629 Internal Drive Component Replacement, External Casing: passo 1, imagem 2 %32 APS Tech 101629 Internal Drive Component Replacement, External Casing: passo 1, imagem 3 %32
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 Internal Drive Component Replacement: passo 2, imagem 1 %32 APS Tech 101629 Internal Drive Component Replacement: passo 2, imagem 2 %32
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 Internal Drive Component Replacement: passo 3, imagem 1 %32 APS Tech 101629 Internal Drive Component Replacement: passo 3, imagem 2 %32
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 Internal Drive Component Replacement: passo 4, imagem 1 %32
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 Internal Drive Component Replacement: passo 5, imagem 1 %32 APS Tech 101629 Internal Drive Component Replacement: passo 5, imagem 2 %32
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 Internal Drive Component Replacement, Internal Drive Component: passo 6, imagem 1 %32 APS Tech 101629 Internal Drive Component Replacement, Internal Drive Component: passo 6, imagem 2 %32
    • Flip so device is upside down.
    • Remove 4 screws with Phillips #1 screw driver.
    • Be sure to save the washers that seperate the screws from the baseplate for reassembly.
  7. APS Tech 101629 Internal Drive Component Replacement: passo 7, imagem 1 %32 APS Tech 101629 Internal Drive Component Replacement: passo 7, imagem 2 %32
    • Slide the internal drive component away from the back of the device.
    • Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
    • Audio Connection
    • SCSI ID
    • Terminate On
    • SCSI Connection
    • DC Input (power)
Conclusão
Alexis Weckel
Membro desde: 04/11/11
140 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 24-60, Amido Spring 2011 Membro de Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 1,148
