Ir para o conteúdo principal
APS Tech 101629 Exhaust Fan Replacement
Patrick Meyer
Patrick Meyer e 6 outros colaboradores
Última atualização em May 28, 2023
25 - 35 minutos
Moderada
Guia em destaque
This repair guide will walk you through the steps to removing and replacing the fan of your APS Tech 101629 CD-Drive. Fans are easily replaced and the process for removing this fan is fairly simple.
First the casing, channel switch, and power switch will need to be removed.
O que você precisa
Ferramentas
Exibir mais…
  1. APS Tech 101629 Exhaust Fan Replacement, External Casing: passo 1, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement, External Casing: passo 1, imagem 2 %32 APS Tech 101629 Exhaust Fan Replacement, External Casing: passo 1, imagem 3 %32
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 Exhaust Fan Replacement: passo 2, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement: passo 2, imagem 2 %32
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 Exhaust Fan Replacement: passo 3, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement: passo 3, imagem 2 %32
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 Exhaust Fan Replacement: passo 4, imagem 1 %32
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 Exhaust Fan Replacement: passo 5, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement: passo 5, imagem 2 %32
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 Exhaust Fan Replacement, Channel Switch: passo 6, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement, Channel Switch: passo 6, imagem 2 %32
    • Find the conjoined ID cable wires that are colored black, orange, and yellow.
    • Lift white portion of cable wires to disconnect it.
  7. APS Tech 101629 Exhaust Fan Replacement: passo 7, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement: passo 7, imagem 2 %32 APS Tech 101629 Exhaust Fan Replacement: passo 7, imagem 3 %32
    • At this point, the fan is loose and can be easily moved but not disconnected.
    • Using the spudger, depress the pressure holders at all four corners of the fan.
    • Take out the fan and its cords, by pulling it outward from its cavity within the device.
  8. APS Tech 101629 Exhaust Fan Replacement, Power Switch: passo 8, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement, Power Switch: passo 8, imagem 2 %32
    • Depress 2 pressure holds on each side of the power switch.
    • Press out the back of the device.
  9. APS Tech 101629 Exhaust Fan Replacement: passo 9, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement: passo 9, imagem 2 %32
    • Remove all four 4 connections from the power switch.
    • Remember that the straight connections are on the far side, while the L-shaped connections are on the near side, and that both yellow connections are on top. This is helpful for reassembly.
    • These are very hard to get off, use patience and wiggling.
  10. APS Tech 101629 Exhaust Fan Replacement, Exhaust Fan: passo 10, imagem 1 %32
    • Remove temperature guage.
  11. APS Tech 101629 Exhaust Fan Replacement: passo 11, imagem 1 %32 APS Tech 101629 Exhaust Fan Replacement: passo 11, imagem 2 %32 APS Tech 101629 Exhaust Fan Replacement: passo 11, imagem 3 %32
    • Move the exhaust fan out of the way so you can access its control cord.
    • Use the spudger to depress the hold on the fan cord.
    • Gently pull fan cord from connection and remove fan completely.
Conclusão
Patrick Meyer
Membro desde: 04/10/11
83 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 24-60, Amido Spring 2011 Membro de Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 704
