APS Tech 101629 Channel Switch Replacement
Introdução
Vá para o passo 1This repair guide will take you through the steps to removing and replacing the channel switch of your APS Tech 101629 CD-Drive. This can be quickly removed and easily replaced.
First the external casing will need to be removed.
O que você precisa
Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
Find the conjoined ID cable wires that are colored black, orange, and yellow.
Lift white portion of cable wires to disconnect it.
Uma outra pessoa concluiu este guia.
