Ir para o conteúdo principal
8BitDo NES30 Pro Gamepad Button Replacement
Daniel Kane
Daniel Kane e um outro colaborador
Última atualização em May 12, 2021
15 minutos
Fácil
Guia do aluno destaque
Use this guide to take the 8BitDo NES30 Pro Gamepad apart and replace its face buttons.
You may want to replace old buttons with a new set as they wear out over time, or maybe you just want to give your controller’s existing buttons a new paint job.
This guide may also be useful if the L and R buttons on the shoulders of the controllers become jammed, meaning they become permanently pressed down. Although the shoulder buttons aren’t removable, you can follow the disassembly process of this guide through Step 3 to access the shoulder buttons and pop them back to their original position.
O que você precisa
Ferramentas
  1. 8BitDo NES30 Pro Gamepad Button Replacement, Button: passo 1, imagem 1 %32 8BitDo NES30 Pro Gamepad Button Replacement, Button: passo 1, imagem 2 %32
    • Hold the controller with its back facing towards you.
    • Insert an opening pick between the L1 or R1 button and the backplate, and pry the backplate off of the controller.
  2. 8BitDo NES30 Pro Gamepad Button Replacement: passo 2, imagem 1 %32 8BitDo NES30 Pro Gamepad Button Replacement: passo 2, imagem 2 %32
    • Place the controller face down on a solid surface.
    • Remove the seven screws with the Phillips #00 screwdriver.
  3. 8BitDo NES30 Pro Gamepad Button Replacement: passo 3, imagem 1 %32
    • Lift the body of the controller up and away from the controller's face and buttons.
  4. 8BitDo NES30 Pro Gamepad Button Replacement: passo 4, imagem 1 %32 8BitDo NES30 Pro Gamepad Button Replacement: passo 4, imagem 2 %32
    • Lift away the black rubber pads that sit between the face buttons and body of the controller.
  5. 8BitDo NES30 Pro Gamepad Button Replacement: passo 5, imagem 1 %32
    • Lift the buttons out of the face of the controller.
  6. 8BitDo NES30 Pro Gamepad Button Replacement: passo 6, imagem 1 %32 8BitDo NES30 Pro Gamepad Button Replacement: passo 6, imagem 2 %32
    • Align the notches of the face buttons to put them back into place.
    • Each button has a unique notch pattern so it can't be replaced incorrectly.
    • Attach the rubber pads by placing their smaller and larger holes around the matching size pegs.
    Hello there, any idea where I can find those black rubber pads for replacement ? mine is torn.
    Thx
    Ben Kakita - Responder
Conclusão
4 comentários
Thx
sorry, i try to search every where, have a tone for other controller, even have for 8bitdo snes, but not for nes 30 pro.
if you find it, answer on that chat. Good luck
Freeman loran - Responder
I wrote 8BitDo support, and explained the issue. They sent me some pads for the price of postage, but only for the buttons -- they didn't send any for the d-pad, which I feel is probably an error on their part.
Izaak Xavier - Responder
The screws in the N30 Pro are #6 Torx now
Matt Baker - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 34
Duração total: 2,249
