Ir para o conteúdo principal
2019 Nissan Sentra Keyless Remote Battery
Sidney
Sidney e um outro colaborador
Última atualização em June 16, 2021
5 - 10 minutos
Fácil
Introdução
Ir para o passo 1
If your 2019 Nissan Sentra car no longer responds to the keyless remote, it is most likely due to a dead battery, which needs to be replaced.
A functioning battery allows your car to receive signals from the keyless remote to perform functions such as unlocking and locking car doors, opening the trunk, and most importantly, starting the car.
The 2019 Nissan Sentra is a push-to-start vehicle and in order to start the car, the key must be in close proximity. Without a functioning battery, the car will not be able to receive signals from the keyless remote to know it is in proximity to start the car.
It is important to replace the battery as soon as possible.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. 2019 Nissan Sentra Keyless Remote Battery, Keyless Remote Battery: passo 1, imagem 1 %32 2019 Nissan Sentra Keyless Remote Battery, Keyless Remote Battery: passo 1, imagem 2 %32 2019 Nissan Sentra Keyless Remote Battery, Keyless Remote Battery: passo 1, imagem 3 %32
    • Remove the key by pulling the lever on the back of the keyless remote.
  2. 2019 Nissan Sentra Keyless Remote Battery: passo 2, imagem 1 %32 2019 Nissan Sentra Keyless Remote Battery: passo 2, imagem 2 %32 2019 Nissan Sentra Keyless Remote Battery: passo 2, imagem 3 %32
    • Use a prying tool to pry the back cover away from the rest of the remote.
  3. 2019 Nissan Sentra Keyless Remote Battery: passo 3, imagem 1 %32 2019 Nissan Sentra Keyless Remote Battery: passo 3, imagem 2 %32
    • Use your fingers to remove the old battery from the remote.
  4. 2019 Nissan Sentra Keyless Remote Battery: passo 4, imagem 1 %32 2019 Nissan Sentra Keyless Remote Battery: passo 4, imagem 2 %32
    • Be sure to verify your new battery matches your old battery.
    • Place the new battery in the remote and firmly press down to make sure it’s secure.
  5. 2019 Nissan Sentra Keyless Remote Battery: passo 5, imagem 1 %32 2019 Nissan Sentra Keyless Remote Battery: passo 5, imagem 2 %32 2019 Nissan Sentra Keyless Remote Battery: passo 5, imagem 3 %32
    • Place the back of the remote back onto the remote.
  6. 2019 Nissan Sentra Keyless Remote Battery: passo 6, imagem 1 %32 2019 Nissan Sentra Keyless Remote Battery: passo 6, imagem 2 %32 2019 Nissan Sentra Keyless Remote Battery: passo 6, imagem 3 %32
    • Once the back is firmly secured on the key remote, place the key back into the remote.
    • Be sure to dispose of the old battery.
  7. 2019 Nissan Sentra Keyless Remote Battery: passo 7, imagem 1 %32
    • Make sure to test the key remote to make sure it is working properly.
Linha de Chegada
Sidney
Membro desde: 02/17/21
193 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 21
Últimos 30 dias: 163
Ao todo: 10,999
