Ir para o conteúdo principal
2010 Jeep Liberty Headlight Bulb Replacement
Ryan Griffin
Ryan Griffin e 6 outros colaboradores
Última atualização em December 16, 2016
30 minutos
Fácil
Precisa de melhores imagens
Headlights are among one of the most important safety devices on a vehicle. They provide you with light to see when it gets dark, as well as be seen by other drivers. This guide is going to demonstrate how to safely and easily replace a headlight bulb on a 2010 Jeep Liberty.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. 2010 Jeep Liberty Headlight Bulb Replacement, Headlight Bulb: passo 1, imagem 1 %32
    • Pop the hood of your vehicle by pulling the lever near the bottom of the driver's side door.
    • Slide your hands under the unlatched hood to find the second lever. Push this lever to the right and lift the hood.
    • Be sure to use the hood prop to keep the hood from falling while you're underneath it.
  2. 2010 Jeep Liberty Headlight Bulb Replacement: passo 2, imagem 1 %32 2010 Jeep Liberty Headlight Bulb Replacement: passo 2, imagem 2 %32 2010 Jeep Liberty Headlight Bulb Replacement: passo 2, imagem 3 %32
    • Identify the bulb socket, located behind the headlight.
    • Rotate the base of the bulb counter-clockwise to remove it from the socket.
    • Remove the bulb from the green base by pulling the two apart.
  3. 2010 Jeep Liberty Headlight Bulb Replacement: passo 3, imagem 1 %32 2010 Jeep Liberty Headlight Bulb Replacement: passo 3, imagem 2 %32 2010 Jeep Liberty Headlight Bulb Replacement: passo 3, imagem 3 %32
    • Insert the new bulb into the green base.
    • Be sure not to touch the glass with your fingers. If you do, wipe the bulb down with a soft cloth and some rubbing alcohol. Oils left behind from your fingers can shorten the life of the bulb.
    • Rotate clockwise to lock the bulb assembly into the socket.
  4. 2010 Jeep Liberty Headlight Bulb Replacement: passo 4, imagem 1 %32
    • Turn on headlights to ensure the new bulb is working properly.
    • You will want to check that your headlights are aligned on both sides. Adjust as needed.
Conclusão
Congratulations! You have a shiny new headlight.
8 outras pessoas executaram este guia.
Ryan Griffin
Membro desde: 01/19/16
245 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 35
Últimos 30 dias: 55
Duração total: 9,434
