Ir para o conteúdo principal
1922 GE AOU Fan Power cord Replacement
Elias Dorna
Elias Dorna e 3 outros colaboradores
Última atualização em August 9, 2019
15 minutos
Fácil
Use this guide to replace the power cord on a 1922 GE AOU fan.
  1. 1922 GE AOU Fan Power cord Replacement, Power cord: passo 1, imagem 1 %32 1922 GE AOU Fan Power cord Replacement, Power cord: passo 1, imagem 2 %32
    • Tip the fan to its side and remove the three size 8 screws using a 9/32 flat-head screwdriver.
    • The screws may be brittle from age, so be careful.
    • Take the bottom plate off the fan and set it aside.
  2. 1922 GE AOU Fan Power cord Replacement: passo 2, imagem 1 %32
    • Remove the three number 8 screws that hold the switch in place.
  3. 1922 GE AOU Fan Power cord Replacement: passo 3, imagem 1 %32
    • Remove the switch, carefully sliding the speed lever out of its slot.
    • Don't remove the switch too quickly or you can damage the head-wire.
  4. 1922 GE AOU Fan Power cord Replacement: passo 4, imagem 1 %32
    • Once the switch is free, unscrew the two knurled nuts holding the wires in place.
  5. 1922 GE AOU Fan Power cord Replacement: passo 5, imagem 1 %32
    • Turn the switch over and unscrew the nut securing the wire with the 5/16 crescent wrench.
  6. 1922 GE AOU Fan Power cord Replacement: passo 6, imagem 1 %32
    • Remove the switch and set it aside, then pull the wire through the grommet.
Conclusão
Uma outra pessoa concluiu este guia.
Elias Dorna
Membro desde: 06/08/16
125 Reputação
Autoria de 1 guia
Equipe
Texas Tech, Team 3-5, Rauch SU 2016 Membro de Texas Tech, Team 3-5, Rauch SU 2016
TTU-RAUCH-SU16S3G5
Membros da 2
1 Guia de autoria
Um comentário
Westinghouse table fan needs new cord (just bought). 18 gauge cord? Where to buy?
carol w - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 2,877
