Ir para o conteúdo principal
Esta unidade resfria ou aquece a água que circula pelo protetor de colchão ChiliPad. Modelo: CP-CUBE
NO Power comnpletely dead
Chilicube has no power. Completely dead. Thermal cutout switch appears not to have tripped as i have tried resetting. Any ideas Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @andrewlovell
Disconnect the power to the device and use a DMM's (digital multimeter) Ohmmeter function to check if the line input fuse F1 has been blown.
Here's a composite image taken from Step.9 of the ifixit Teardown do ChiliCube da ChiliTechnology guide showing where the fuse is located.
If it has blown unfortunately I can't zoom in close enough on the image to read the specifications that are printed on the fuse case. You may have better luck. If you go to order a replacement get 2 or 3 as fuses generally don't fail of their own accord. If the replacement fuse also fails then the reason for this will have to be found.
Imagem
(click on image)
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thanks for the info. I will let you know how i progress.
por Compartilhar
Fuse is good. So still looking.
por Compartilhar
Adicionar a sua resposta
Andrew Lovell será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 7
Últimos 30 dias: 35
Ao todo: 138
