Ir para o conteúdo principal
Dell Inspiron 9100 laptop with double row rear connections and 15.4 inch screen
Won't come on screen when turn on
Screen go blank after window xp pop up
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Does your screen remain properly visible when your computer stays on? Does your screen stay visible when you access the BIOS?. I would try a Linux Live CD and boot from that. See if your screen remains visible. Right now it does sound like a Windows problem more than a computer problem. Have you tried to safe boot windows and checked your drivers?
por
Adicionar um comentário
2 respostas
Solução escolhida
Here is a link to a copy of your service manual. Good luck.
http://support.dell.com/support/edocs/sy...
Esta resposta foi útil?
Pontuação 3
Related Parts and Tools
First try to check your power supply using a voltmeter if your getting the appropriate voltages or not then try to re-install the windows by following steps:
In case you dont have a disk you can install windows using a USB flash drive by following these steps:
Step 1- Download ISO image of Windows from: windows.microsoft.com/ website
Step 2: Download YUMI from: www.pendrivelinux.com/yumi-multiboot-usb-creator/ website?
Step 3- Plug in your USB in pc.
Step 4: Run YUMI and follow the on-screen instructions by selecting the appropriate operating system.
Step 5: Give path of the ISO Image and select the USB drive to make boot-able disc
Step 6- Plug in the USB onto the system on which you need to install the windows.
Step 7- Turn on the system.(Change the boot preferences to USB if the system do not automatically start booting from USB).
Step 8- follow the on screen instructions to complete the windows installation.
Pontuação 0
Adicionar a sua resposta
Aihvixaythong será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 957
