Ir para o conteúdo principal
iFixit uses cookies to enhance site functionality, analyze traffic, and personalize ads. By using our site, you agree to our cookie use and Privacy Policy.
Nintendo Game Boy Advance, released in 2001. Repair requires only common tools and no heat.
20 Perguntas Visualizar todos
Gameboy Advance - doesn't turn ON (ON/OFF switch cleaned)
Hi guys!
I have this old GBA which doesn't work and I decided to try to repair it. There was battery leak inside and the power button was damaged. At first the gameboy didn't turn at all. I disassembled it, opened the power switch, cleaned it up and I now it's still not working (haha) but there is som led blinking for a while and just a milisecond buzzing sound from the speaker.
I have also tried to jump the switch ON pins with a wire to bypass the switch but the result was the same.
I have also checked continuity from + -> F1 -> 101 -> Q5
No screen at all...could you please help me what should I try next?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi there!
The only advise I can give you is to replace the ON/OFF power switch.
If this didn't worked, please check the traces there. It's possible that the traces and/or the solder pads are damaged and causing this.
As far as I can see, this is related to the power switch or it's traces or solder pads...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
wiston será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 43
