Ir para o conteúdo principal
Nintendo Game Boy Advance, released in 2001. Repair requires only common tools and no heat.
20 Perguntas Visualizar todos
Gameboy Advance Won't Turn on, but...
I have a Gameboy Advance I Attempt to turn on, and wont, but when I switch from On to back Off there is a quick green flash.
I've replaced the power switch twice. What could be causing this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi!
The "Quick green flash" is related to the power button, usually.
Can you share some pictures with us? It's possible that there are some damaged traces there (near the power switch), causing this.
Also check the battery pins if they are OK.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
GameboyFan32 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 26
