Ir para o conteúdo principal
Apartado dedicado a reparaciones varias que no tengan relacion con electrodomesticos o equipos electricos, mas enfocado a madera, montaje de muebles y reparaciones del hogar
Toilet's push button doesn't flush
I was flushing my toilet yesterday normally but today when I push the button it didn't return to its original position, after I opened the lid I realized that the button doesn't reach the little plastic the flushes the water I don't know if something fell or got lost but how could I fix this
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
If you have not got a new cistern by now, then have a look in the bottom of the cistern to see if any (broken) bits have fallen there. They might show what piece is missing. In my experience, sometimes you might be able to craft a replacement, but buying parts is not possible. A new cistern has usually been the result. Just be sure the replacement you fit is level, or the mechanism might not work properly (they run on water levels). Good luck
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Erik Samkeit será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 66
Ao todo: 1,500
