@reiny until @benz78 can work on this, there are a few things you can already check. There are definitely a variety of things that could cause this. The best way of determining where the error originates from, would be by measuring the voltage on the display connector. For now, we are making the assumption that your logic board is a 820-00163-A. If so, then you have to measure the voltage on pin 1 of your eDP connector (display adapter) Now, here is the challenge. This will have to be tested with the computer on. That means there will be full operating voltages on the logic board. You will have to be careful that you do not cause a short with the probes from your multimeter. I use needle tip probes for testing those. You could possibly measure that voltage on C8306 as well.
As a general rule of thumb, the voltage on the pin gives us an idea of what has failed. If the voltage is high (greater then 45V), there will be no load. That means your backlights in the panel have failed and are not drawing any power. This could mean that you may need a new LCD. If the voltage is anywhere between 24V-40V, your boost circuit etc. works as designed. That would point toward a bad connector, bad cable and again a bad LCD. If the voltage is present but low, the failure will be with the boost circuit. If the voltage is 0 then the issue will be with the power circuit. Could be a bad fuse, LCD, backlight FET or the enable transistor.
Sounds complicated, it's not. We just need those values and then we can hopefully help you to repair your MBP. It will always help to see your logic board. That way we can look at the components and see if there is any obvious damage (i.e. water damage, corrosion etc.)
Translation
@reiny bis @benz78 sich darum kümmern kann, gibt es ein paar Dinge, die du schon mal überprüfen kannst. Es gibt definitiv eine Vielzahl von Dingen, die das verursachen könnten. Der beste Weg, um festzustellen, woher der Fehler kommt, wäre, die Spannung am Display-Anschluss zu messen. Im Moment gehen wir davon aus, dass es sich bei deiner Hauptplatine um eine 820-00163-A handelt. Wenn dem so ist, musst du die Spannung an Pin 1 deines eDP-Steckers (Display-Adapter) messen. Hier liegt die Herausforderung. Dies muss bei eingeschaltetem Computer getestet werden. Das bedeutet, dass die volle Betriebsspannung auf der Hauptplatine anliegt. Du musst darauf achten, dass du mit den Sonden deines Multimeters keinen Kurzschluss verursachst. Ich habe einige Nadelspitzen-Sonden zum Testen. Du könntest diese Spannung möglicherweise auch an C8306 messen.
Als allgemeine Faustregel gilt, dass die Spannung am Pin uns eine Vorstellung davon gibt, was ausgefallen ist. Wenn die Spannung hoch ist (über 45 V), gibt es keine Last, was bedeutet, dass deine Hintergrundbeleuchtung im Panel ausgefallen ist und keinen Strom zieht. Das bedeutet, dass du möglicherweise ein neues LCD benötigst. Wenn die Spannung zwischen 24 V und 40 V liegt, funktioniert dein Boost-Schaltkreis usw. wie vorgesehen. Das würde auf einen schlechten Stecker, ein schlechtes Kabel und wiederum auf ein schlechtes LCD hindeuten. Wenn die Spannung vorhanden, aber niedrig ist, liegt der Fehler beim Boost-Schaltkreis. Wenn die Spannung 0 ist, liegt das Problem beim Stromkreis. Es könnte eine schlechte Sicherung, ein LCD-Hintergrundbeleuchtungs-FET oder der Aktivierungstransistor sein.
Klingt kompliziert, ist es aber nicht. Wir brauchen nur diese Werte und können dir dann hoffentlich bei der Reparatur deines MBP helfen. Es ist immer hilfreich, dein Motherboard zu sehen. So können wir uns die Komponenten ansehen und feststellen, ob es offensichtliche Schäden gibt (z. B. Wasserschäden, Korrosion usw.).
https://de.ifixit.com/Anleitung/Bilder+z...
1 comentário
@reiny this "KEINEN solchen Schutzkontakt hat (stattdessen: nur 2 Kontakte). Kennt man so von manchen Auslandsadaptern. Könnte es daran gelegen haben? Kann ich mir kaum vorstellen?" would not impact the backlight.
por oldturkey03
