Ir para o conteúdo principal
Great vacuum and easy to repair.
1 Perguntas Visualizar todos
Why won't my vacuum turn on?
Oreck won't turn on and handle power switch doesn't illuminate.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
The electrical connector to the switch itself may be disconnected inside the handle.
  • After the obvious try a different outlet, verify the cord is plugged in both ends.
  • The connections to the illuminated switch in the handle are pressed on. After repeated dropping of the handle onto the floor, a switch connector may have fallen off the switch.
  • Unplug the unit and remove the screws holding the two sides of the handle together. Locate the loose wire and plug it back into the switch lug.
  • Loosely assemble the handle, plug in the vac and give it a try. If it turns on tighten the screws.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Randy Tolleson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 54
Duração total: 1,006
