Ir para o conteúdo principal
My screen is white after water damage
my ipod has been in my cra for a couple of days and has got water damage how will i be able to fix this ????
please get bak to me soon
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
eddie123, my suggestion is to follow this guide. Disassemble your iPod by using these guides Clean the board with plenty of high percentage isopropyl alcohol to prevent corrosion and failure later on. Clean the cable ends and the connectors as well. Replace your battery, Lithium Ion batteries do not like water at all. After you have it clean and replaced the battery, reassemble your iPod and re-evaluate for any further damage. Good Luck.
Esta resposta foi útil?
Pontuação 2
1. Open up Ipod and remove LCD
2. Put ipod in a bowl of uncooked rice for 1 week to dry
3. While waiting for it to dry order new LCD
4. When New LCD arrives insert into ipod
5. Plug sync cable into ipod to see if boots and you get something on screen
6a. if doesn't boot then battery may need replacement
6b. if does boot then put digitizer back on and enjoy
Pontuação 1
1 comentário:
Whoa, why a week? What happens with the corrosion and the starch you will leave with the rice?
por
Adicionar a sua resposta
eddie123 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 340
