Ir para o conteúdo principal
Bluetooth, compatível com Google Play, 8 GB de armazenamento disponível.
Continuous bootloop Android phone
My Android Rebel 4 is stuck in continuous bootloop. How do I fix this
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Hi @nettie162774 ,
Try removing the battery then wait for 5 minutes before placing it back in and then try to turn on the phone.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thanks for the suggestion.
por Compartilhar
LG is known to have bootloop issues that are related to bad boards. Sadly it’s usually not something you can fix with a battery removal. The board needs to be reworked to run for data recovery and it needs to be replaced. Been there with my G4 and it’s still been my last LG to this day. Supposedly the phones like the G6 and subsequent models from that point are okay, but the damage is done - too little, too late. They seem to go bad within ~2 years from what I’m aware of.
In an answer to my own question on this exact same issue. It isn’t easy, so make sure you can do it because you usually only have one chance and a few reruns and it’s over. Refer to this question: How do I get the phone working for data recovery?
Pontuação 0
Adicionar a sua resposta
Lynette Anderson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 490
