Ir para o conteúdo principal
Model No. A1367 / 8, 16, 32, or 64 GB capacity
20 Perguntas Visualizar todos
Pergunta encerrada
Anytime crazy lines appear HHEELLPP
I had it working but i slammed on the power then when i start it it shows lines and restarts in classic mode
Esta é uma boa pergunta?
Pontuação 0
4 comentários
Need a bit more information about what you are trying to fix. What lines? When do they appear? What did you fix, or install? How did you "slammed on the power"?
por
DUDE they appear when i turn it on there lines that i get no apps i did not install anything i broke the power and home button -_-
por
Well dude, I guess it's time to like open it up and re-evalute the damage. Looks like you need some new parts. Like here is a good start...iPod Touch 4th Generation
por
i dont need a screen i need a home button the home button is cracked -_-
por
Adicionar um comentário
3 respostas
Pergunta mais útil
First, I would suggest restoring the software using iTunes. Just plug in your iPod to your computer, open iTunes, and restore the system (make sure your music is all backed up in iTunes first).
If, after restoring, it is still showing lines, then probably you need a new LCD screen. They're not currently available on iFixit, but you should be able to buy one on eBay, or send it in for professional repair.
Let me know if you still can't get it!
Esta resposta foi útil?
Pontuação 1
3 comentários:
I don't have any apps that say itunes in classic mode and i need a home button
por
you are still looking for the same button? this question is almost a year old...:-) Did you not check the link that I posted in December? Here is where you can get the button http://www.amazon.com/Home-Button-Apple-...
por
ok i just needed a button i will follow the steps
por
Here is your LCD screen, iFixit sells it!
iPod touch (4th Gen) Screen
Imagem de Replace a front glass screen digitizer compatible with the fourth generation iPod Touch model A1367.
Produto
$29.99
Pontuação 1
1 comentário:
i needa button
por
Try this link
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,168
