Ir para o conteúdo principal
Repair guides and support for sinks, taps and faucets in your kitchen or bathroom.
14 Perguntas Visualizar todos
Faucet handle won't come off to repair leak
Plumber ended up just scratching finish in attempt to remove handle! Any suggestions?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Do you have a specific model, brand, or anything? There's not enough information here.
por
Adicionar um comentário
2 respostas
Solução escolhida
Hire a REAL plumber!!!! or…
If you get the brand, model number, etc. it is easy to look up on the web.
You can even find repair kits. We fixed our Metheven kitchen mixer tap for about $15.
All that was needed was a Philips screw driver.
Esta resposta foi útil?
Pontuação 1
It the cover has no flats so as to accommodate an adjustable wrench, then try a rubber strap wrench. If the cover is made of thin metal over plastic as many are today, then be careful not apply too much force because the fulcrum of the strap wrench may dent or crease the thin metal.
Pontuação 1
Adicionar a sua resposta
Jessie MCKillop será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 293
