Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
20 Perguntas Visualizar todos
What's the difference between MZ-JPV5120/0A4 and MZ-JPV512S/0A4?
There is just one letter difference between those two SSD's, MZ-JPV5120/0A4 and MZ-JPV512S/0A4.
Sometime, the model number ends with "/0A2".
What's the difference?
Will any of them work if I put it in my iMac 27 5k?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Your iMac uses a custom PCIe/NVMe SSD. Apple has two versions of these a 2 lane (x2) and a 4 lane (x4). So far Apple is the only source for the x4 SSD's OWC & Transcend offer x2 units.
As for taking a MacBook Pro SSD and using it: Only the newer models (2015) have PCIe/NVMe drives, the previous generations used a PCIe/AHCI and the oldest models are SATA/AHCI.
So before you pull the SSD from your MacBook Pro go into 'About this Mac' and click System Report so you can check which SSD you have.
Here's a great diagram which explains the different interfaces:
Esta resposta foi útil?
Pontuação 2
2 comentários:
Hi there, thanks for you response. I forgot to mention that my iMac is a Late 2015 so that would work. Is there any reason for the slightly different model number? Sometimes it's JPV5120, and sometimes it's JPV512S.
por
@alex22254662 - Unless you changed the SSD the model ID doesn’t change. Apple did use two other vendors for the mSATA and PCIe/AHCI drives.
por
The R is a model code variation that means it comes with a metal heat spreader (used in ‘13 Mac Pro) so I’d imagine the S means something similar - the actual SSDs are the same.
I’m not sure what 0AX number means, perhaps it identifies the factory it was made in?
Here are some 512 GB examples:
2013 MBP MZ-JPU512T/0A6 SSUAX is slow (x2) PCIe/AHCI
2015 MBP MZ-JPV5120/0A4 SSUBX is faster (x2) PCIe/NVMe
2019 iMac MZ-KKW5120/0A7 SSPOLARIS is ridiculously fast, larger card but still fits in MBP 2015. (x4) PCIe/NVMe
In terms of speed:
SSUAX < SSUBX < SSPOLARIS
Slower ——————- faster
If buying used, remember to ask the seller for this DriveDX information: Overall Health and Lifetime Left Indicator.
Pontuação 2
1 comentário:
The SSPOLARIS is not only fast but also consumes less power 2.6A@3.3V compared to 3.2A@3.3V for the SSUBX when considering 512GB+.
por
Adicionar a sua resposta
Alex222 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 52
Ao todo: 10,290
