Why can't my Dell Inspiron 1525 charge the replacement battery?
Battery doesn't hold any charge.
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
Ok so what I would do is look for a replacement battery on Amazon, like this one:
Dell Inspiron 1525 Battery - Amazon
Try using that, and it should work just fine.
- Jasen
Esta resposta foi útil?
if Ur useing a new battery then u probably need to replace the charger port
I have replace the battery & also replace the charger port , then same problem could not charging the battery…..
now what can I do…..?
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 10
Duração total: 445
3 comentários
Is it a new battery that you're trying to use?
por Jasen Friedle
No, it's an old replacement battery and the electrical cord is used as well. Has been worked on prior times, not me. Trying to save the laptop since it's my only backup and my Mac doesn't have microsoft cause I can't afford to buy the approved programs.
por Maria
Use this : Dell AC Adapter LA90PM130
por Steve Redtone
