Ir para o conteúdo principal
The Asus ZenPad S8 is an 8-inch Android tablet by Asus. Released in June of 2015. Model number: Z580CA.
Replaced broken screen but touchscreen doesn't work
Hello,
I've recently replaced the screen of a Asus Zenpad Z580CA. Haven't glued the screen on yet, just connected all the cables and booted it to see if it works. No issues with the screen itself, everything looks fine. But I have no response to touch. Anywhere i press there is no response, it's not a few dead zones, the whole screen isn't working. Should I replace the screen again or could it be that something is badly connected? And if so what cables/circuitboards manage the touchscreen?
Thanks in advance for the help!
Update (07/16/2017)
I have no idea what else I can try...
Help would be greatly appreciated
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
change your screan and try again
Esta resposta foi útil?
Pontuação 0
did you insert the touch screen flexible correctly?
Pontuação 0
4 comentários:
I assume so.
Which ribboncable is the one that connects the touchscreen?
por
i 'm not sure about the position of the cable itself usually every cable must be fit to the socket just make sure it is well positioned and locked
por
Refitted all cables a few times now, cleaned all contacts as well. Both no luck
por
are you sure the touchscreen is not broken? try another touch screen module hope work
por
Adicionar a sua resposta
Ziyedm será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 358
