Ir para o conteúdo principal
A Big Wheel is a type of tricycle, usually made of plastic, with an oversized front wheel, that rides very low to the ground.
Steering column is stiff
I recently put together a kids big wheel and the steering column is very stiff and will hardly turn. Obviously this isn't something that is adjustable given the set up, but I need simple solution so my three year can steer it. Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Try adjusting the height of the handlebars by loosing the screw in step #5 of this PDF and lifting slightly till it turns freely then tighten it back down:
originalbigwheelparts.com/images/bw_assy_instructions_pictoral.pdf
Esta resposta foi útil?
Pontuação 2
4 comentários:
Kristina Johnson, This may also help, take the column back apart and apply a little/ thin coating of Vaseline on column and reassemble. Good luck.
por
Neither of the above helped a bit. Cannot be steered by a child.
por
Item is a piece of junk.
por
Agree, the Big Wheel has been unused for over a year. Every few months my kids and their friends get on it and just as quickly get off. I would greatly appreciate someone sharing a fix if there is one out there
por
Gear Up For Future Repairs
Adicionar a sua resposta
Kristina Johnson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 26
Ao todo: 1,849
