Ir para o conteúdo principal
HP's base model notebook PC for the Pavilion zv5000 series released in 2004. Capable of providing a cutting-edge gaming experience for mid-2000s media.
5 Perguntas Visualizar todos
Why won't my laptop charge?
I'm having difficulty charging my laptop. The charger looks good (no wires bent, exposed, etc.) and it is plugged in to both the wall outlet and the port on the computer but no charging light is on and it will not charge, help please?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I would first check to make sure that there isn't any debris in the charging socket or battery socket.
If after cleaning out the sockets and still no charge, then I would ask a friends for his/her charger and if that works then you need a need charger but if not I would suggest replacing the battery.
Hope this helps!!
Esta resposta foi útil?
Pontuação 0
2 comentários:
Does anyone have a charger for my hp Pavillion. O bought one on the internet. But the the end going into the computer is slightly larger. Does anyone have one to fit?
por
My question from above. The end of the one I bought on the internet is slightly larger in diameter.
por
Adicionar a sua resposta
Eliza Marks será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 453
