Ir para o conteúdo principal
Fujifilm FinePix 16.4 megapixel HD waterproof digital camera has the ability to capture up to 10.10fps. Released on 2015.
10 Perguntas Visualizar todos
Why won't my camera focus?
My camera worked fine before, but now my images are coming out blurry. I have tried resetting the device and it seemed to not work. How can I get my device to focus again?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
If you are having issues with image clarity, make sure that the subject is not too far or too close to the camera itself. This may seem like a simple solution but it is often effective. Also check to make sure that nothing is blocking the lens and that it is clean. If these solutions do not work, try using your device in focus lock which can be enabled by depressing the shutter button halfway.
Hope this helps, and good luck!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Daniela Pesci será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,630
